Disables the XNV feature on the switch.
Disabled.
This command disables the XNV feature, which tracks virtual machines (VMs) that connect to the switch.
When the VM tracking feature is disabled, file synchronization with the FTP server stops.
The following command disables the XNV feature:
# disable vm-tracking
This command was first available in ExtremeXOS 12.5.
